Help from the gang on dizzy tech
Folks, I'm up the creek on this one. I thought I was being smart by installing an HEI procom dizzy on my 351W HO but I've been made the fool. It's been over a month dealing with procomp and I'm not getting anywhere...
Here's what I have so far on the HEI dizzy:
My rotor is turning, I hooked a 12v source directly to the "batt" connector. I have "ohmed" the base of the dizzy to the block, and I have a good ground. I have rotated the engine to top dead center. I aligned #1 piston with the #1 plug wire and the rotor pointing in that spot. Timing marks also line up correctly. Still no spark to the plug.
The reason I'm not using the duraspark, I do not have the unit itself and the dizzy took some damage. I'm ready to go this route and get a duraspark unit. but I don;t know where to start without dropping $400+ on all new stuff. I read somewhere now that I'm not using the EGR junk on my engine the stock dizzy would have to be rebuilt. And If I was to source a Duraspark unit from the junk yard any way to check it??
I'd be very appreciative of any help on either subject..
thanks all
bob
thanks all
bob
