explorer coded ignition keys
Old Feb 9, 2003 | 09:13 AM
jeepcat's Avatar
jeepcat
Angry explorer coded ignition keys
Can anyone tell me how an ignition key would all of the sudden become uncoded?Recently my key will just let the motor turn over and not start.Driving me crazy. THANKS!
Old Feb 9, 2003 | 08:41 PM
thelonerangerxlt's Avatar
thelonerangerxlt
JeepCat, do you have a second key to try? I thought the engine wouldn't even turn over if the coded key was at fault.....
You may have another starting problem, other than the key.
Old Feb 9, 2003 | 08:55 PM
dro man's Avatar
dro man
if the key is the problem you should have rapidly blinking theft lamp.the starter interupt varries, some have it some dont. i'm pretty sure the explorer DOES.
Old Feb 10, 2003 | 04:24 PM
jeepcat's Avatar
jeepcat
Post explorer coded ignition keys
I have 2 keys, the one key will start the vehicle just fine , but the other key will only let the engine crank over but no start . This key will make the theft light flash rapidly as well.
Old Feb 10, 2003 | 06:14 PM
1956MarkII's Avatar
1956MarkII
When the anti-theft kicks in, it allows the engine to turn over but not fire. Also, the anti-theft light will flash rapidly.
As to the one key not working, you'll have to have your local dealer re-program that key. There are various reasons that could cause this: Any larger metal object coming near the ignition when you're trying to start it (like a heavy house key), magnetic interference, moisture, etc...
Old Feb 10, 2003 | 06:55 PM
jeepcat's Avatar
jeepcat
Yes I do have a second key.I will have to head to the dealer to have key recoded.......thankyou much.
Old Feb 10, 2003 | 07:22 PM
dro man's Avatar
dro man
do you happen to have a third key?
