Steering gear box seal
Old Jul 5, 2010 | 05:58 PM
therockgod's Avatar
therockgod
The steering gear on my 80' F100 is leaking p/s fluid where the pitman arm connects. I've ordered a new seal(it should be here tomorrow) but my Chilton book gives little clues on how to install it. Any ideas?
Old Jul 5, 2010 | 06:00 PM
cadunkle's Avatar
cadunkle
Pull pitman arm, pull seal, replace, install pitman arm. Should be pretty straightforward.
Old Jul 5, 2010 | 06:06 PM
Franklin2's Avatar
Franklin2
Mine started gushing after I hit a curb. I got a whole rebuilt box and replaced the whole thing. I am glad I did because it steers so much better now, and it doesn't leak either.
Old Jul 5, 2010 | 06:10 PM
therockgod's Avatar
therockgod
yeah, it looks pretty simple,just something I've never done before and thought there might be a trick or two I should know first.Thanks.
Old Jul 6, 2010 | 12:31 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
It'll likely just leak again in a short time, it's more than likely wore out and the shaft is moving around.
-Enjoy
fh : )_~
Old Jul 6, 2010 | 12:54 AM
kermmydog's Avatar
kermmydog
Smile
-Enjoy
fh : )_~
I was going to say the same thing. As a rule when they start leaking it is a sign the box is wore out. What I did was add Lucas Trans Stop Leak until I finally put in a rebuilt box. A few years back CarQuest Auto Parts sold the best rebuilds.
Craig
Old Jul 6, 2010 | 06:30 AM
bashby's Avatar
bashby
After you remove the pitman arm and the snap ring that holds the seal in, start the truck and turn the wheel to full lock, the pressure will pop the old seal out. Be sure to put a drainpan under it!
70-360fe
Jul 1, 2013 09:00 AM
kill_them_all
Jul 13, 2010 03:10 PM
FordTrucksKickGM
Nov 24, 2008 12:22 AM
vulch
1983 - 2012 Ranger & B-Series
Nov 21, 2004 09:13 PM
HardFordCore
Mar 3, 2004 05:53 AM
