Sponsored by: Real Truck
intermittent blower motor problems
Old Jun 7, 2020 | 01:14 PM
Skirider527's Avatar
Skirider527
Same problem
Originally Posted by John Boughton
This is a reply to a thread but is good for everyone . I am a troubleshooter of electrical refrigeration , heating , auto motive , etc. electrician 43 years .
I want all to know that when terminals are burned up it is due to a loose connection...nothing else . If there were too much current the whole wire would melt. Regarding motors gong out. : either bearings are bad or windings open or melt (burn)together. the relation mentioned above of higher mileage trucks is just due to a long time of heating of the loose connections. The heating is caused by arcing which acts like electric welding on a small scale. I hope this helps you all sometime in your troubleshooting.
So my AC when I start the truck will work fine if I shut it off after period of time the AC does not work with that be the resistor or the motor
Old Jun 7, 2020 | 06:05 PM
Lance Kohler's Avatar
Lance Kohler
Originally Posted by cw45
I have the same or similiar problem with my 250 super duty. Blower motor cuts on and off randomly. I replaced the resistor pack and it didnt make any difference.
When it works the fan will blow in all speeds. Could the blower motor itself be going out or is the switch more likely?
Thanks for any input.
our wash truck with 425,000kms had same issue, the plug to the motor was all corroded and screwed up we replaced the blower motor before finding out so now we have a spare blower lol
Old Aug 30, 2021 | 03:36 PM
Reel Escape's Avatar
Reel Escape
Okay I have to bring this message back to the top. I have a 2011 F250 Lariat with digital dual climate control. The blower motor turns on and off at random. I just repaced the resistor...PITA!! Unfortuantely it still has the intermittent issue. I did not check the connector to the resistor. I guess I was just in too much of a hurry to get it done since it's a long job. I forgot to check it. Anyway, I have searched this issue on the web and this forum for days. I am just looking for some direction. I've seen where some have said they had a ground problem and others saying that their ground/wiring problem was due to a bad blower causing too much resistance and damaging the ground. Any advice would be great.
Old Aug 30, 2021 | 07:11 PM
Reel Escape
Update
So I went ahead and replaced the blower motor this evening and the intermittent issue still persists. 🤦‍♂️
Old Aug 31, 2021 | 12:03 PM
Reel Escape
Does anyone know if they sell the plug that connects to the resistor and what the part number would be? Maybe where I can find a parts catalog that I can search through the graphics and pic out hte part I'm looking for?
wharthog
18
Nov 19, 2019 09:06 PM
Niceguyeddie69
Jan 3, 2018 06:23 AM
jafare
Nov 19, 2017 06:42 PM
cmcdonald375
Mar 8, 2017 03:57 AM
Ford99508
2004 - 2008 F150
Jan 9, 2017 04:59 PM
