controling egts!
I totally agree with you mountaineer27, cooler is better!! but don't worry about it as long as they are not staying high, I know x temps are the same in chipped and stock trucks, but just for your info, here are my average temps, cruising at 60mph (2000rpm)-600deg., 0-60mph, shifting at 2200rpm (foot on the floor in each gear up to 2200) 1000deg., towing 8,000lbs on flat ground at 60mph,750-780deg., and at idle it is 250deg. Like I said pulling up that 4 mile hill I stay at around 1100-1150, and if I accelerate up the hill I can pass1200deg.
Yeah, I think you have a problem, near me there is a 1/4 mile hill that is quite steep and empty coming back from town there was a guy right on my bumper so at the bottom of the hill I put my foot on the floor and went from 60 to 75mph up that hill and I didn't get to 1100 deg. I personally don't know what your problem is, does the truck run ok besides the high temps?
For me I get the white smoke in the morning but that is typically condensation build up, I think. The white smoke goes away the longer it warms up. Not a big deal for me
1200* in a chipped truck and 1200* in a non chipped truck are the same temp. i understand what your saying about about piston temps and the oil jets but im saying for extended periods it cant disapate the heat. now i do understand some of the 7.3 oil jets get clogged and that leads to alot of the piston failures but i dont want to end up getting a crack in a piston from long exposures to high heat day in and day out. with that being said there is always a good reason to look for ways to reduce the egts. i maybe worring for nothing but i really dont wanna rebuild a motor when a 200-300 dollar part could fix it or something as simple as a boost leak could be fixed. i guess its that military ORM thats burnt into my brain. do the benifits out way the risk?
Think small and work your way up to the bigger things.. I.E. boost leaks, turbo, injectors.
i know my injectors arent stock but it shouldnt make my egts any lower than any other truck, on stock it is very difficult to get anything over 1100 max no matter were i am, slow speeds ******* or hauling some butt on the highway.on stock with an intercooler i pull around 16~18 lbs of boost. with the chip up to blow people away its hard to hit anything over 1300 degrees of egts pulling 26lbs of boost with the wrong tuning.
12lbs of boost is kinda low for a chipped truck, i lost about 4lbs of boost adding an intercooler, but on a stock truck with a chip you can hit a good 18-20lbs.
how ever, when i cracked my injector tip or wheni was running on 7 cylinders when my poppet valve crapped out, my egts were terrible, you may possibly have a weak injector or 2, might be time for an over haul, plungers and barrels might be in order.
this white smoke is semi conserning, how long does it smoke for, just in the mornings like usual trucks or way more?
#30
