fuel line size
Old Jul 4, 2010 | 05:24 PM
poocher pup's Avatar
poocher pup
fuel line size
i need to know what the i.d. size is of the pex fuel supply line coming from the fuel tanks? also if you can buy the ends where the line connects to the metal nipple on the sending units at a auto parts store or if you have to go to Ford ? i need this information today if possible so can have truck running again before surgery on tuesday. thanks in advance guys.
Old Jul 4, 2010 | 05:42 PM
typefour's Avatar
typefour
If your auto parts does not have the repair line kits then some rubber fuel line and clamps will work fine for a long time.
Supply is 3/8 and the return is 5/16
Old Jul 4, 2010 | 11:36 PM
LCAM-01XA's Avatar
LCAM-01XA
parts stores only have short pieces of line with the fittings attached to it - do like Russ said, rubber hose is what I have in my truck and it works just fine
