S. California Chapter Join Chapter, Leader:
EMERGENCY!!!! EMERGENCY!!!! EMERGENCY!!!!
Old Jul 7, 2010 | 02:41 PM
Sparx Macgyver's Avatar
Sparx Macgyver
Lol, well it was a hot day and it was a big puddle...plus shes a big truck..I couldn't resist..
Old Jul 7, 2010 | 02:49 PM
Snowbunny's Avatar
Snowbunny
LoL!! You boys and your toys!! My son would have done the same thing!!
Old Jul 7, 2010 | 03:00 PM
Sparx Macgyver
Haha.
It was a "free" car wash.
My pops would've done the same thing if he was there too. I suppose you could say like father, like son.
Old Jul 7, 2010 | 04:04 PM
Snowbunny's Avatar
Snowbunny
So, how'd you turn out?? Get her home yet??
Old Jul 7, 2010 | 06:45 PM
Sparx Macgyver
Yeah, pulled it home last night.
Old Jul 12, 2010 | 01:51 AM
Sparx Macgyver
So an update. I finally had a day off where I didn't have to do anything!!!! So, following the advice of a friend, I bought the filter and gasket, then waited for it cool a bit. Did the deed, and I don't think I fixed it. This little metal piece popped out. Kinda looks like a really miniature version of a ratchet adapter. Anyway, which way does this thing go in? With the "bib" end pointed towards the trans/truck, or towards the street?
And, after cleaning up all my tools and having put everything back together, I found a small spring. I believe it goes with the metal thingy I found. How are these pieces set up? Otherwise, Everything else went without a hitch.
Old Jul 12, 2010 | 06:29 PM
Sparx Macgyver
Ok, well, finished everything I started yesterday. And nothing. I have reverse, but no forward. Everything seems to check out fine, but I just don't have any forward momentum or anyhting.
Old Jul 12, 2010 | 07:01 PM
orng1's Avatar
orng1
Did you let it idle long or just start it and try. My truck has no gear until after the truck has warmed up a bit.
Old Jul 12, 2010 | 07:26 PM
Sparx Macgyver
I let ti idle for a time. I'm going to go back down in just a bit and give it another go. Just to double check and give ti a chance to warm up again.
Old Jul 12, 2010 | 08:40 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
If you've got a few extra parts laying around afterward chances are it's not going to work properly whether it's warmed up or not.
You might want to try posting in the transmission forum and see what kind of response you get.
Old Jul 12, 2010 | 11:54 PM
Sparx Macgyver
[face palm] I should! I will.
Nope, no etra parts. I fixed that. All parts were properly installed earlier today. But still no forward. I let it sit and idle and what not. Nothing.
Old Jul 12, 2010 | 11:57 PM
orng1's Avatar
orng1
Well these trucks are a lot cheaper to repair, have you called a repair shop to get a quote on repairing that transmission? I've seen a few of these trucks in the junk yard too. It may work as a temporary solution until you get a rebuild.
Old Jul 13, 2010 | 12:21 AM
  #28
Sparx Macgyver
That's my next hopeful choice. That opr a master repair kit from rockauto.com
Quoted around $1500 and j\higher. Lowest I had was $600. Either way, I dont hasve that kinda money.
Old Jul 13, 2010 | 12:26 AM
  #29
orng1's Avatar
orng1
I was quoted $900 for a reman on mine, I know that the older ones are a lot cheaper. You should be able to install the trans on your own that's what I want to do. But I also need a torque converter and I'm not going to use a stock one.
Old Jul 13, 2010 | 12:38 AM
  #30
Sparx Macgyver
Ah. See, I haven't found a reman one. They seem to be elusive.
