water injection issues
Old Jul 3, 2010 | 07:14 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
finished hooking up my snow stage 2. I can't get anything out of it. I tested the pump, it's good. Have power to the control module,pump,and switch. I'm lost, no clue what i'm missing. Any ideas would be great. Thanks in advance.
Old Jul 3, 2010 | 10:52 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Did you use the troubleshooting in the manual?
Old Jul 4, 2010 | 08:41 AM
whitewhale's Avatar
whitewhale
Maybe you're not reaching the right PSI/Temp(don't know which one is used on that system) for the system to kick in. On my cheap set up I had a solenoid that opened at a certain PSI of boost.
Old Jul 4, 2010 | 11:51 AM
diesel-fitter-bum01
It has a control module that I can set when I want the water to start and when I want it to spray at 100%. It is run by the boost levels. I would think with the gtp38r I wouldn't have that problem. I even tried unplugging the wastegate for more boost. Just can't get it to kick on. Sent snow tech an e-mail also hopefully will hear something from them also. Just figured I would ask experience too.
Old Jul 4, 2010 | 12:45 PM
Riffraff Diesel
PREMIUM SPONSOR
How do you know it isn't kicking on? Use the troubleshooting in the back of the manual to verify fluid flow. It will have you move your setting way down and then blow into the tube. Unhook your nozzle so that you can visually verify spray and not put fluid in your engine.
Old Jul 4, 2010 | 01:37 PM
diesel-fitter-bum01
Water level hasn't changed. It's been over 100 miles since install. I'm going to try blowing into the boost tube again later. Ran some different grounds. Will update later,at a family function currently.
Old Jul 4, 2010 | 03:28 PM
Riffraff Diesel
PREMIUM SPONSOR
Unless you are running extremely heavy injection it isn't going to change much in 100 miles since your boost has to reach the level everytime for it to inject. Try function testing like it shows in the manual and let us know.
Old Jul 4, 2010 | 03:46 PM
diesel-fitter-bum01
Will do. Thanks
Old Jul 7, 2010 | 01:20 AM
diesel-fitter-bum01
everything works in the system. I have done several wot runs and the water level is not changing. Could my boost line be too big? Because if I blow into the hose it will kick on the pump and spray. It's a good spray also not weak at all. Maybe I will try a smaller diameter hose, mine is pretty big. Don't know, out of options and ideas.
Old Jul 7, 2010 | 08:50 AM
kirkharrod's Avatar
kirkharrod
When I first installed my WI system, I put the pump and tank in the back seat so i could hear it kick on. I did this so I could monitor it until I was sure it was working. I also installed an LED light on the dash to tell me when the pump has power, and therefore, is spraying.
How about running a loop of the water hose into the cab so you can see if there is water moving through it as you drive?
Is your boost switch set correctly?
Old Jul 7, 2010 | 03:07 PM
CSIPSD's Avatar
CSIPSD
What boost levels do you have your water injection set to come on at? Do you have gauges?
1/8" boost line is all you need for the pump, but it makes no matter the size, boost is boost, Pressure is Pressure.
I can drink 8 gallons in about 450 miles if I just leave it on.
Old Jul 7, 2010 | 04:58 PM
diesel-fitter-bum01
Currently its turned all the way down. I'm going to hook a dummy light to the pump so I know if it is actually coming on or not. It should be noticeable when its working right?
Old Jul 7, 2010 | 05:14 PM
diesel-fitter-bum01
Oh and my banks boost gauge just took a dive so I'm unsure of my boost psi currently. Will be getting new gauges shortly though. Boost,another pyro and trans.
Old Jul 7, 2010 | 07:37 PM
CSIPSD's Avatar
CSIPSD
Water will give you no more power, your EGT's will just stop climbing. You need to ajust it to where it comes on at about 10 psi. No less or you risk putting out the flame.
I also run a LED set up in the A pillar, one is on to show the system is armed and one that shows the water is on...
YouTube - 50# with water on Turbonetics BB
They both come on in this video because I turn it on when I was already at 40+ pounds of boost.
There you can see just the green LED for the system on...
YouTube - Glow plug light
There is a red LED for the Glow Plug relay as well...
Old Jul 7, 2010 | 08:30 PM
hucka1a's Avatar
hucka1a
Joe, seriously man. You NEED to get some gauges....
