Sponsored by: Real Truck
installing a tach....
Old Feb 8, 2003 | 09:04 PM
Iceman_19's Avatar
Iceman_19
where do i find the 12v dash lighting for the tach? im sure some people here have installed tachs in their superduties. this is a 91 f-superduty with a 460. help!
Old Feb 8, 2003 | 10:56 PM
Racerguy's Avatar
Racerguy
Probably the easiest place to find a good source for the light is at the headlight switch. The brown wire is for the park lights and that would work. I believe the dash lights are a light blue with red wire but I'm not positive. Take a test light and check to see what wire has power when.
Old Feb 11, 2003 | 07:40 PM
Iceman_19's Avatar
Iceman_19
well where do you hook the green wire on the coil? we were trying to find it but we cant see where to put it.
Old Feb 11, 2003 | 09:36 PM
Racerguy's Avatar
Racerguy
You use the wire on the negative side of the coil....tan with yellow stripe.
Old Feb 12, 2003 | 02:00 AM
Iceman_19's Avatar
Iceman_19
do you just splice into it or just hook it up to the negative terminal?
Old Feb 12, 2003 | 09:05 AM
Racerguy's Avatar
Racerguy
You splice the green wire from the tach to the tan wire at the coil.
