Sponsored by: Innova
AM Buzz when braking or A/C on! Help.
Old Jul 2, 2010 | 06:14 PM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
My AM radio buzzes pretty bad when I brake or when the A/C fan switch is moved to any position except low. What can I do to eliminate the buzzing?
Ted
Old Jul 2, 2010 | 08:10 PM
twg1966's Avatar
twg1966
I don't guess there is much I can do about it.
Old Jul 6, 2010 | 07:43 PM
fl1a's Avatar
fl1a
Some simple things to check... First make sure your battery clamps and terminals are fully clean and tight. I can usually tell that I have left them too long when I hear any noise from the brake lights or fan, or when other things are switched on. Second, check the grounding on your radio, and the antenna cable from your radio to the antenna. It has a ground shield that runs to the antenna and should be in good shape. I'll bet your battery connections will have a definite effect, without opening up the dash though. Good luck.
Old Jul 6, 2010 | 10:59 PM
twg1966's Avatar
twg1966
Thanks for the reply. I will check the battery cables first. Then look for the dash grounding.
