Help, won't start
Old Jul 1, 2010 | 11:17 PM
CT's Avatar
CT
Question Help, won't start
I'm driving a 1992 Ranger my Dad loaned to me, with the inline 4-banger engine and five-speed manual transmission. I'm not very familiar with these vehicles. After several starts with no problems over the day, the Ranger was shut off for fifteen minutes at a fast-food restuarant and wouldn't start. There seems to be no response of any kind under the hood when the key is turned. The warning buzzer for key in the ignition still sounds. I thought maybe the battery might be down, so tried to jump-start it with no response. Could it be the safety switch on the clutch? Are there any related fuses or breakers? I'm puzzled after not being able to jump-start it. I'm working two jobs so don't have much time to work on it, but don't have the money right now to take it to a garage. Thanks for any ideas.
Old Jul 2, 2010 | 07:51 AM
pawpaw's Avatar
pawpaw
Could be a number of things & you've already put two of them on your suspect list.
Has it given any previous signs at all lately of trouble starting????
Maybe consider beginning with some quck basic trouble shooting to try & narrow it down.
To do a rough battery load & cable connection test, how bright are the head lights when you turn them on, then how bright are they when you try to crank the engine????
If thats ok, do you hear any under hood "click" when you try to crank the engine???
If not, then begin an inspection of the starter control electrical wiring, connection & components.
Look for broken wires, loose or corroded connections.
If that;s ok, try thumping or wiggeling things like the key in the ignition swich, clutch/neutral start switch & it's wiring, starter relay, solenoid & the starter motor.
Will it start & run if it's pushed & you pop the clutch in 1'st gear to spin the motor over????
Let us know what you find.
Old Jul 2, 2010 | 09:14 AM
Hank85713's Avatar
Hank85713
could also be the fuel pump relay, read my response to the issue a couple of posts don on replacing a fuel pump/fuel pump problems.
Old Jul 2, 2010 | 02:08 PM
powersmoked's Avatar
powersmoked
i think from his description the truck is not cranking over at all.....it is not the fuel pump relay......
Old Jul 2, 2010 | 02:12 PM
powersmoked
do like pawpaw suggested........doe sit pop start.....do your headlights work. do the dash light al come on when you turn it to the run position......if the answer is yeas and it pops starts it could be the clutch switch, the starter, the fender relay, the wires to these things.......
Old Jul 2, 2010 | 11:54 PM
CT's Avatar
CT
I borrowed a bigger pickup tonight and pulled it and it started right off. Before that I cleaned up the battery terminals and cables. I drove it for 15 miles and everything seemed normal. Even started again after I shut it off, so maybe there was just a bad cable connection. I still can't figure why I wasn't able to start it with jumper cables. Whether it starts or not tomorrow, I plan on trying to get the battery tested, it is getting some age on it. And I will park in open spaces! By the way, what exactly do you mean by the "fender relay"? Thanks for all the good input.
Old Jul 3, 2010 | 05:51 AM
powersmoked
it could be the cable connections on the starter/solenoid. it could be the cable themselves. it could be the starter
