64 Dash Restore
Old Jul 1, 2010 | 08:49 PM
dadwood's Avatar
dadwood
64 Dash Restore
Men, as I start of this journey to fix our 64 Flareside 1/2 ton have a few as always since I be a worm (in oilfield talk that means inexperniced) in restoring old trucks so here goes.
  1. Someone painted the dash and it looks like crap. Can this be removed and painted? If not what is the best method for painting it while being installed?
  2. Do most people try and stay with orginal gauges or do they go with a newe gauge cluster? I only have the big dial gauge and two empty (no gauges ever mounted) stops.
Just wondering, there is soooo much to do. And I thank all the smart answer folks here, you guys are awsome.
Dadwood
Old Jul 1, 2010 | 09:08 PM
Bill W's Avatar
Bill W
No, the dash can not be removed... it is welded in.
First remove everything you can from the dash and tape off/mask up what you can not.
If the dash is rough start with 220-240 grit and move to 320 grit befor painting or primer
light coats are better than one heavy coat.
you can look at the new digital gauge clusters from dakota digital, but they are lot's of money.
Old Jul 1, 2010 | 09:24 PM
camperspecial65's Avatar
camperspecial65
the digital stuff requires a buttload of wiring stuff too...keep what you got...if it isnt broken...dont mess with it is my philosophy...as for the painting...Bill is right...mask(get the blue EZ to remove tape...great stuff...I would do the dash cluster bezel seperate...then you can spend more time and get the bad black off of those umpteen ribs in it...
Sanding...if theres no primer under it and it looks like cheap rattle can stuff done in a rush...I would start with 320..go up to 600 for the finish sanding...use wet/dry paper...it will last plenty long...keep it wet though...undo the battery cable so the water wont short anything..and hang onto the worn out paper are good for finish sanding on small projects like this. I definately would NOT remove the original white paint underneath...it could be red...depends on the original colors...removing the cluster or looking in the small inner edges of the glove box will show the original color...either way, keep the original paint...its a solid as a rock base for covering...removing the switches...not hard at all...when you get to that point, drop me an email as I have that already done as a few on here have asked about that in the past.
- cs65
Old Jul 2, 2010 | 12:17 AM
Broomfieldbum's Avatar
Broomfieldbum
Hey I know a place in Denver, that has a really nice stock gauge set with all gauges no idiot lights. Message me if you want to get the info about it.
