Timing Cover Question - 90 F150 302
Old Jul 1, 2010 | 05:13 PM
lizardlust's Avatar
lizardlust
I have come across something that I am unsure about on my truck and I was wondering if anyone in here could help me. I have a 1990 F150 with the 302 - as far as I can tell, the motor is original to the truck. I need to replace the timing cover due to cracking behind the water pump. The issue that I have is that I find two possible part apps for this truck's timing cover - one is equipped with a crankshaft position sensor hole, the other one does not. Does anyone know which of the two would be correct for my truck?? The date of manufacture is 10/89 at the Norfolk, VA plant.
Old Jul 1, 2010 | 05:26 PM
EPNCSU2006's Avatar
EPNCSU2006
Your truck should use the one without the sensor mounting hole.
Old Jul 1, 2010 | 07:40 PM
lizardlust's Avatar
lizardlust
Thanks for the information, Eric - I do appreciate the help!!!
