runs like a bag of bolts unless under load
like the title says my 1988, 7.3 na hates life unless its in a gear, but in park or N. it hits and misses terribly, but not rythmically. i thought it was a air intrusion issue, but no dice, i have replaced all of the return lines, boots and o rings, to no avail. i replace the burnt out coolent temp. switch, replaced the dead vacuum pump, tried diesel kleen in the filter to loosen anything up. any other ideas. ITs a wierd issue because once its in gear its happy but whe its just idling unloaded it shakes rattles and smokes.
