Whistle from the engine when it is cold out...
Old Jun 30, 2010 | 12:19 PM
Nickgolf101's Avatar
Nickgolf101
I have a 2003 Expo and in the winter time when I start the truck it whistles until it warms up. Only happens when the outside temp is 35 or below.
Can anyone help with this issue?
Thanks!
Old Jun 30, 2010 | 01:25 PM
alloro's Avatar
alloro
I had a bad bearing in one of the belt idler pulleys do this, which went away when it warmed up. Here is another possibility:
https://www.ford-trucks.com/forums/5...ter-issue.html
Old Jul 3, 2010 | 11:37 AM
skipppy75's Avatar
skipppy75
check your vacume hose conectors they may be leaking when cold and expand when warm to close the air leak off
Old Jul 17, 2010 | 12:35 PM
alfie623's Avatar
alfie623
Thanks!
Check the gasket around the engine air filter door. I had the same problem and bought gasket material from HD, cut and trimmed it and put it on the door and the noise went away. Another option is to buy a new door for big bucks.
Old Jul 20, 2010 | 04:05 PM
Pro DIY's Avatar
Pro DIY
good to know, I always wondered what that sound was from
billhutch
Jun 8, 2011 03:29 PM
njexpo
1997 - 2003 F150
Jun 15, 2010 11:17 PM
BOTMHEVY
Jun 5, 2006 10:15 AM
New2003Expo
39
Aug 7, 2003 05:51 PM
HookedUp2003
Aug 2, 2003 06:00 PM
