Fuel Pump Help Please
Old Jun 30, 2010 | 03:22 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Get ride of that POS pump, it's junk!
That is the same pump one of the classes of cars I work on is required to run, they are JUNK! I have seen more than one race lost do to it's failure.
I highly suggest going to the factory manual diaphragm pump.
-Enjoy
fh : )_~
Old Jun 30, 2010 | 03:24 PM
Festus Hagen
Methanoholic
Originally Posted by Rogue_Wulff
Good idea!
Cheap chineese made crap.
Cause they were convinced that mechanical pumps are inferior to electric. Which you now know to be not true.
AMEN!
I whole heartily agree!
-Enjoy
fh : )_~
Old Jun 30, 2010 | 03:29 PM
dvideo22's Avatar
dvideo22
Thanks so much guys will do!
Old Jul 3, 2010 | 09:58 AM
dvideo22's Avatar
dvideo22
Machanical Pump Install
So I bought the Mechanical pump and went to install..... uh, feel like an idiot, I can't find where it goes. This truck has always had a electrical fuel pump since I owned it. Back by the tank.
1980 F100 300-6
I always assumed an its got an original motor...
There seems to be a spot low on the block where it might go, there's 2 semi-holes and an oval like flat spot, like it was part of the mold for some models...?
Anyone shed some light on this for me?
Ya, look @ this pic, that is where the flat spot is on mine, cept - no hole for pump, What gives?
Old Jul 3, 2010 | 11:34 AM
bashby's Avatar
bashby
Sounds like someone swapped in a engine from a FI truck and converted it to carb, so you're gonna need an electric pump. I have no personal experience with them but have heard the Holley blue pumps are good.
Old Jul 3, 2010 | 11:38 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Well, if that spot on your engine doesn't have the hole for the fuel pump arm to go into, you have a later model engine that had EFI originally.
In that situation, your only route is to go with an electric pump.
Unfortunately, most of the stuff sold at the big chain parts suppliers is cheap crap, that won't last very long. You've already encountered that. You may need to bite the bullet, and pay a bit more for a higher quality pump. Using a return style pressure regulator, and plumbing in a return fuel line should extend the life of the pricier pumps.
Old Jul 4, 2010 | 12:44 PM
Festus Hagen
Methanoholic
If you do wind up having to stick with a electric, I have had good luck with Mr. Gasket 12s
They need no regulator or return system.
You want a pump that produces 2-7PSI, no more.
For ease of explanation you do not want a round type, you want a square type ... The reason I say that is most (not all) round types are gear pumps, gear pumps require a recirculating system to keep them cool... Some gear type pumps have internal recirculating bypasses not all. So for ease of identification stick with a square pump.
-Enjoy
fh : )_~
Old Jul 4, 2010 | 01:05 PM
Rogue_Wulff
One of my RX7's has one of those square pumps, and when the car is first started, the fuel pressure guage reads a solid 6 PSI. After 20-30 minutes, I'm lucky if it shows more than 2 PSI. However, it has never failed to supply enough volume to feed the edelbrock 600, even when the guage reads less than 2 PSI.
Always make sure you have a good filter between the pump and tank, to keep debris out of the pump. That can dramatically shorten pump life.
tom42nm
May 11, 2012 09:04 AM
shorebird
Sep 25, 2011 10:00 AM
Wicked Endings
13
Feb 9, 2011 07:04 PM
tseekins
40
Sep 9, 2009 07:53 PM
canadian mole
30
Oct 19, 2008 01:32 PM
