Sponsored by: Real Truck
Steering stuck for a second
Old Jun 29, 2010 | 01:16 PM
samiott's Avatar
samiott
04 F350 6.0. Making a left turn from an off-ramp, the steering stuck straight for a second then quickly popped left. Its been fine ever since but still has me concerned.
Any ideas?
Thanks
Old Jun 29, 2010 | 05:25 PM
bpounds's Avatar
bpounds
If it is 4WD, probably the front wheel U-joints are dry or failed.
Old Jun 29, 2010 | 07:16 PM
blockmanjohn's Avatar
blockmanjohn
The same thing happened to me twice, only it was a right hand off ramp. I took it to the dealer both times after it happened, but they couldn't find the problem. They said it might be due to my large tires. A couple months later they replaced my passenger side ball joints and the wheel problem has never happened again. Hope this helps a bit.
Old Jun 29, 2010 | 07:20 PM
rudedogii's Avatar
rudedogii
Check
Check out the Tie Rods! Make sure nothing is rubbing! My alingment guy left this clamp thing loose and it flopped over and made contact with the differentail cover. I all most went into the curb!
