Sponsored by: Real Truck
08 PSD value?
Old Jun 29, 2010 | 08:52 AM
Biggziff's Avatar
Biggziff
08 PSD value?
I found a clean 08 with the 6.4. 40K miles, lariat, leather, 20's, CC, LWB, power/heated seats, etc. 3.73 rear diff...is that normal for a SRW diesel? I can buy it for $30K-$31K. Sticker was $53K. Oasis shows the following:
This series of repairs were all done at the same time in the early fall of 08 over 3 days in the shop approximately 26K miles at the time:
AC wasn't cold, evac and recharge, no leaks found with dye test
Cooling T gasket installed per recall 08B06
Complaint of CEL, surge and low power... CEL code P003, TSB 07 26 02 performed, replaced gasket on pump..also says harness shorted.
Truck quit running, towed in. Says KOEO P0090 short to ground. Pulled cab per Hotline contact, checked connector which was fine. Road test was good (40 miles)
Recall 08B07, reprogrammed PCM, TCM and Instrument cluster
Recall 08C01 installed damper seal clamp
One month later....28K miles:
Complaint of hard to start, and exhaust cleaning filter light on, tool icon light on. Pumping accel would allow vehicle to start....Code P2201 in continuous memory, tried to do manual regen which failed. Found high pressure fuel pump leaking, pulled cab and replaced HPFP which corrected issue.
That's all Oasis found. Last warranty work was in fall of 08. No open campaigns, one ARN message regarding 09-08-05 (Cooling system nitrate level issue)
Truck has had no body damage, original tires (I'm assuming these are nearing their end of life with 40K??) and looks about as clean as you could find without going new. So...any thoughts on what it's worth or issues I should be concerned with?
thanks much...
