Please Help Diagnose my Cooling problem
Old Jun 28, 2010 | 05:38 PM
shadowznyc's Avatar
shadowznyc
Hello, i have a 1999 Ford E150 4.2 V.6. When driving the van after fifteen minutes or so the dash temperature guage shoots from middle to high. The van i not overheating but the dash temp light comes on and the temp guage jumps to hot acting as if there was a dead short somewhere. Where does the temperature guage gets its signal from? Thermostat housing? Whats the correct technical term for that guage switch? Does anyone have a schematic of the motor layout i can take a look at?
Please help
thanks
Old Jun 29, 2010 | 12:36 PM
wizzy214's Avatar
wizzy214
sounds like your thermostat is stuck open or closed, their cheap just replace it.
Old Jul 1, 2010 | 06:25 AM
first_stater's Avatar
first_stater
I've got a similar problem. Also my lighting flickers constantly. I'm wondering if I have regulator/gen problems that is causing reference voltage problems to the sensors and PCM? I'll post what I find.
Old Jul 3, 2010 | 02:49 PM
Grems4ever's Avatar
Grems4ever
I'd replace the thermostat just to be safe and then find someone with an advanced scan gauge to check the reference temp from the temp sensor. You could have a bad sensor as well.
Let us know about the charging system check. That used to happen frequently with bad alternators in older vehicles, but I haven't encountered it in a newer one.
