Sponsored by: Auxito
are all flexplates/flywheels the same
Old Jun 28, 2010 | 05:38 PM
hornsurgeon's Avatar
hornsurgeon
well, i'm looking at having to replace my flexplate/flywheel. there must be a bad spot on mine causing the starter issue i've been having. are the ones from autozone/advance/etc as good as the ford part? or is there a better aftermarket part?
Old Jun 29, 2010 | 01:03 AM
Bluegrass 7's Avatar
Bluegrass 7
Which motor do you have, 4.2, 4.6 or 5.4 liter?
There are two different designs. One built in Canada and one in Mich.
One difference you need to know for sure is the number of bolts holding the flex plate on.
The engine ID is all you should need to know.
In the VIN number, the 8th digit position will tell you what motor you have.
One of the following should be there.
2 = 4.2 L. V6
W = 4.6 L ROMEO V8 engine. (US).
6 = 4.6 L Windsor V8 engine. ( Canada).
L = 5.4 L V8.
The 4.6 motors can have the different bolt patterns.
Order accordingly.
Good luck.
Old Jun 29, 2010 | 06:53 AM
hornsurgeon
it is a 5.4L. i'm just wondering about part qualitys in general - ford, autozone, advance, o'reily, etc.
Old Jun 29, 2010 | 09:37 AM
joerickson's Avatar
joerickson
you can usually just buy the ring gear for the flexplate and have it pressed on at a machine shop
they should carry just the ring gear at most auto part stores
MECHANICTIME
Apr 22, 2007 11:25 PM
mizzitch
Dec 9, 2005 11:19 AM
gustaf-dgm
Oct 30, 2004 01:19 PM
