transmission question help
Old Jun 28, 2010 | 06:14 AM
fixitman1310's Avatar
fixitman1310
96 f250 ps 145,000 mi auto/od
hey guys i think i need a tranny. is there a tranny out there
that will work other than the e40d. i dont do any towing with truck.
how hard is it to switch to 5 speed.
thanx for any help
steve n.carolina
Old Jun 28, 2010 | 10:39 AM
redman84's Avatar
redman84
The 5 speed swap ended up being surprisingly simple. The EASIEST and cheapest thing would be to take it in for rebuild. The flat out CHEAPEST would be to drop it yourself and take it in for rebuild. Other options, get another tranny from salvage yard if they will guarantee it to run but it may go in 10 miles then back at square 1.
In answer to your question, I believe a 4R100 will work in it but is probably going to be more $$ than E4OD.
Old Jun 28, 2010 | 04:47 PM
fixitman1310
thanx alot for your help. is there a procedure or write up to your knowledge on here
with what i need to do in relationship to electronics, plugs wires etc. i know how
to do tranny and clutch. did you change steering column
thanx again
steve
Old Jun 28, 2010 | 06:00 PM
redman84's Avatar
redman84
thanx again
steve
No write up yet. Working on one though. Check out the current thread "5 Speed Swap" on the same page as this thread. Should answer each question you just asked.
