Computer Chips & Tuners
Chip Question
Old Feb 7, 2003 | 10:42 PM
MastercutzLawnCare's Avatar
MastercutzLawnCare
Chip Question
Hey I have a 95 F-350 with a 460 engine, iI installed a superchip but after alot of cleaning it is still wanting to load the motor with fuel, and just does not run right, can anyone help with the problem, I do't know if it was set up wrong or what, the computer code is DOE0, but on the door jam I also noticed a calbrtion code, si that the one they need to program or what, any help would be greatly apperciated.
Thanks,
Brian
Old Feb 10, 2003 | 08:21 PM
FTE Ken's Avatar
FTE Ken
Chip Question
What name did you order this under so I can look up the code? Why is the truck running too rich in stock form (that needs to be addressed)? The chip will lean out the mixture slightly but if there's a tuning problem with the stock truck that needs to be addressed. What do you mean by "just does not run right?" Yes, the calibration is important.
Old Feb 10, 2003 | 09:35 PM
MastercutzLawnCare
Chip Question
Thanks, but got it fixed, they entered the wrong code, and the truck was running fine without the chip, just running rich with the chip installed, but it is ok now.
Brian
