Sponsored by: Real Truck
Help finding BLACK bed rail caps!
Old Jun 27, 2010 | 08:32 AM
wgm114's Avatar
wgm114
I am trying to find BLACK plastic rail caps (covers)/ tailgate cap (cover) for 2001 F250 SD w/ 6' bed. The ones the factory installed are a grey color. All I am able to find is for F150 online.
Anyone have a link I can use? I know Ford installed black in other years so even if I could find the OEM black ones to fit, that would be great.
Thanks!
Bill
Old Jun 27, 2010 | 09:05 AM
ReAX's Avatar
ReAX
I'd look with my favorites, BAK's are the most precise I worked with. Wade was nice because of the textures available. Bushwacker was a good standby, but I didn't like the drop down by the tailgate. All of these should just stick over any OE should they make them for your application.
I don't know of any aftermarket factory replacements, but you may check with your local body shops. They may have a supplier not in the accessory world.
Old Jun 27, 2010 | 11:48 AM
sammy77's Avatar
sammy77
On my 250 I had removed them and had the holes filled, painted then Rhino-lined them.
Old Jun 27, 2010 | 12:27 PM
MRUGG's Avatar
MRUGG
chedk out cabelas.com I just got catalog from them and they have black ones.
Old Jun 27, 2010 | 01:22 PM
wgm114's Avatar
wgm114
Thanks guys. Unfortunately none of those offer the rail caps for a 2001 F250. They do for an F150 and all other years of F250. For some reason NOBODY offers plastic bed rail caps for years 99-04 F250SD. Don't understand it.
Old Jun 27, 2010 | 02:24 PM
nedburg's Avatar
nedburg
Don't know if you want to go this root, you can always get some good used ones or new and paint them, I painted all my plastic, bed rail, and plastic on my bumpers with fusion paint for plastic, turned out great...
Old Jun 27, 2010 | 02:36 PM
06silvercrew's Avatar
06silvercrew
The OEM ones on my 06 are black.
Old Jun 27, 2010 | 03:00 PM
MRUGG's Avatar
MRUGG
I dug out my new cabelas book to make sure.They are for 99-06 F-250/350.Bed rail and tailgate cap.Made by DEEZEE rails $109.99 and tail gate cap is $29.99.Yes they com in black.Bed rail part number is 52-3322 and the tailgate cap part number is 52-0158.Hope this helps you out a little better.
Old Jun 27, 2010 | 03:02 PM
TennesseeMustangPerf's Avatar
Same here on my 2003.
You can get some trim paint from Advance Auto (the one with the green label) and it works great! Identical to the OEM color.
Old Jun 28, 2010 | 05:41 PM
wgm114's Avatar
wgm114
Outstanding! Thanks for all the help!
Old Jun 28, 2010 | 09:03 PM
F350-6's Avatar
F350-6
Sounds like there's hope yet. Last time I checked I couldn't find anything either. I'll check the DeeZee part, or might just use the plastic paint. Thanks for the ideas.
Old Jun 28, 2010 | 09:40 PM
If you shoot them in black trim paint it will take around a half an hour and you will be absolutely amazed at the results!
tcrimsonk
17
Jan 8, 2012 09:10 AM
79BRNC
Aug 6, 2008 12:30 PM
wgm114
Aftermarket Products
Feb 7, 2005 06:10 PM
Wendell
Appearance & Dress-Up
Jun 10, 2003 07:22 PM
