Sponsored by: Real Truck
Another Dumb Question....
Old Jun 26, 2010 | 10:01 PM
erniesshop's Avatar
erniesshop
I'm Starting to have Problems seeing at Night....
I have a 01 SD.....What's The Easiest Upgrade I can do to Get Brighter Headlight's ?
Thanks Guy's !
Old Jun 26, 2010 | 10:46 PM
JockD's Avatar
JockD
'02-type headlight units. Plug-n-play.
I did that and built a harness using relays to take power directly from the battery (using a remote fuse box) using larger wire for less voltage drop than the undersized factory harness. Between the two, my headlights are as bright as my wife's new Honda Pilot.
Let there be light!
Old Jun 26, 2010 | 11:01 PM
erniesshop's Avatar
erniesshop
Let there be light!
Thanks.......What's the deal with the Harley Headlight's ?
Old Jun 27, 2010 | 02:53 PM
TennesseeMustangPerf's Avatar
Also invest in some Sylvania SilverStar bulbs. $40 well spent!
Old Jun 27, 2010 | 02:58 PM
QwkTrip's Avatar
QwkTrip
When is the last time you changed light bulbs? They do wear out over time and put out less light.
Also, is your lense cover cloudy? You can make it clear again very easily with a lens buff kit from any auto store. I did this last spring and it makes a difference.
Old Jun 27, 2010 | 03:04 PM
ChargersFanInCO's Avatar
ChargersFanInCO
My F250 vs my old (2008) F150 is night and day. The F250 outshines it by far. Talk about going blind, try driving my Fusion at night if you don't know the road...
The optometrist should be able to help you out though...
Old Jun 27, 2010 | 04:37 PM
erniesshop's Avatar
erniesshop
I just changed them out last month.....Not much Help ......
