Kiko-
Search the message boards - I know this was discussed in detail a while back. You may want to use "fuel rail" as a keyword, because I think you need to move it to change plugs.
Jerm
Gather an array of extensions, wobbles, flex shafts, universal joints, and ratchet drives of various drive sizes. also you may want a mechanics mirror, and a set mechanical fingers (grabber)
Step 3
Take a deep breath and gather your patience, there is no quick way to do this (unless you have the smallest double jointed hands in the neighborhood)
Step 4
Get out your service manual, Mark all lines and wires that you remove, you may be able to get away with not removing the fuel rail, but I had to.
If upgrading the injectors is on your agenda, do it now.
If you have an easy time performing this change, you are twisted,(or very skilled) I became frustrated and cursed alot, but I finished in about 5 hours (my back hurts just thinking about it).
My advice to you, farm this one out to a professional tech. (a reputable and patient one)
