Belts.
Old Jun 25, 2010 | 08:47 PM
mabc926's Avatar
mabc926
Belts.
Anyone have some pictures of the fan belts on there truck?
Once I get the belts on all I have to do is put some diesel in the tank drop the battery(s) in and this b***h is ready to run!
Also will one battery be enough to start it?
Thanks guys.
Old Jun 25, 2010 | 08:55 PM
poocher pup's Avatar
poocher pup
probally not if cold, they will run fine on just one battery as i have pull started mine before got starter fixed and new batteries.
Old Jun 25, 2010 | 10:17 PM
banks7.3's Avatar
banks7.3
use jumper cables or a charger and then one battery should get you going.
Old Jun 25, 2010 | 10:28 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
id plug the heater in too.
if its a nice new starter,just don't do it.wait until you can afford another battery.
Old Jun 25, 2010 | 11:00 PM
mabc926's Avatar
mabc926
Gonna be going to a diesel salvage yard to look for other parts just gonna pickup a used 12 volt there.....don't want to fry my starter and have something else to fix! lol
Old Jun 26, 2010 | 12:18 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Belt routes ...
Inside = Closest to motor.
Outside = Front of truck.
NON A/C
Inside belt is, Crank, Alternator, Water Pump/Fan.
Middle belt is, Crank, Vacuum Pump, Water Pump/Fan.
Outside belt is, Crank, Water Pump/Fan, Power steering.
A/C
Middle belt is, Crank, Water Pump/Fan, Power steering.
Outside belt is, Crank, Water Pump/Fan, A/C.
Vacuum pump is run off the Outside on Alternator.
Hope thats clear.
-Enjoy
fh : )_~
Old Jun 26, 2010 | 12:46 AM
swooshcmk's Avatar
swooshcmk
If you still want a picture I can take one tomorrow.. just bought new belts today and I've got the engine on the stand yet! She's going in the frame tomorrow! Oh I'm so giddy with excitement.. lol
Old Jun 26, 2010 | 02:20 AM
LCAM-01XA's Avatar
LCAM-01XA
Originally Posted by Festus Hagen
Belt routes ...
NON A/C
Not always the case - most "work" trucks I've seen for instance have the alternator and vacuum pump and power steering belts arrangement just like the A/C models, but instead of the A/C the outside belt drives the PS pump again (that makes two belts for the PS pump).
Old Jun 26, 2010 | 02:23 AM
swooshcmk's Avatar
swooshcmk
Hrmm.. wonder how hard it'd be to dig up a dual belt PS pulley. I could use the extra to drive my York for on-board air!
Old Jun 26, 2010 | 02:27 AM
LCAM-01XA's Avatar
LCAM-01XA
Both the setup Festus described and the one I just mentioned are achieved with a dual-groove pulley. The PSpump in these trucks is the same pump Ford used for like 20 years straight, so you may have a decent luck for finding a pulley like that if you look in early-'80s Ford vehicles.
Old Jun 26, 2010 | 08:08 AM
mabc926's Avatar
mabc926
Belt routes ...
NON A/C
A/C
Hope thats clear.
-Enjoy
fh : )_~
Thanks Festus!
That's how I thought it was but I just wanted to make sure.
Old Jun 26, 2010 | 03:04 PM
rhkcommander959's Avatar
rhkcommander959
just in time for my belt change
alternator/water/crank belt thing is tight until the motor turns... stretched out belt
