A/C help
Old Jun 25, 2010 | 07:45 PM
kevinarnold021692's Avatar
kevinarnold021692
A/C help
i know there has been a lot of these but my trucks a/c don't work
i know my step dad charged it 2 years ago and if i remember it didn't last long
what are some things to do to find out what is wrong
money is a problem to just test something so tricks i can do to find something out for free are some things i will try
please help me getting it working cause im tired of sweating like crazy even with the windows down its really humid here
Old Jun 25, 2010 | 08:42 PM
redlightning93's Avatar
redlightning93
Well Kevin..... first, welcome to FTE and there is a lot of help here for you but we need to know a little more about you truck and what specific problem(s) you are having with your a/c.
1. Year and model of your truck.
2. What happens when you turn your a/c on?
3. Does the fan motor run?
4. Does the Compressor turn at all?
You say it was charged about two years ago so did it cool at that time? Post back here and I am sure we can give you some tips to get you started cooling again.
Old Jun 25, 2010 | 09:03 PM
kevinarnold021692
lol ops i always forget to put my truck down
its a 94 ford f150 with the 5.8L in it and 4x4
the fan works my heater works fine
and the compressor turns
it was cold when we charged it
when i turn it on it blows but warm air
Old Jun 25, 2010 | 09:16 PM
redlightning93
OK....we are getting there now. You say the compressor turns but let me ask you, is the center of the compressor turning or just the outside of the pulley? Do you hear the compressor "click in" when you turn the a/c on?
Old Jun 26, 2010 | 05:57 AM
StealthWyvern's Avatar
StealthWyvern
Check your low and high side pressure valves... they might be leaking. Thankfully those things just screw on or well I know the high side does.
Old Jun 26, 2010 | 07:49 AM
subford's Avatar
subford
My guess is it has a leak and needs to be recharged.
Old Jun 26, 2010 | 10:38 AM
kevinarnold021692
ok my compressor, the center isn't turning, so i guessing thats the problem, what can i do
Old Jun 26, 2010 | 10:49 AM
subford's Avatar
subford
Put gauges on it and if it is low recharge it or look for the leak.
Old Jun 26, 2010 | 11:15 AM
kevinarnold021692
ill check for leaks after i figure out the compressor cause the clutch is not engaging so that is looking like my problem cause it blows cold at the beginning and its going to cost to check for leaks and money is very tight
iv checked the fuse and it was fine and i even replaced it with a new one just to be sure and it was the a/c clutch fuse not the blower my blower works fine
so how do i make sure its the clutch and can i just replace the clutch maybe instead of the whole compressor or even fix it some how cause a new compressor is around 200 and i don't really have that
Old Jun 26, 2010 | 11:29 AM
subford's Avatar
subford
I do not understand why you think the clutch is bad.
If it is low on gas the clutch will not work.
To check the clutch if you must unplug the low pressure cutout and jumper the two wires.
Do not run the AC very long this way as it will burn up the compressor as it will not have cooling.
Old Jun 26, 2010 | 11:51 AM
kevinarnold021692
is that the plug on the back of the compressor
thats what im guessing cause i guess the front on is for the clutch
Old Jun 26, 2010 | 11:53 AM
kevinarnold021692
and where do i cross them
on the compressor or the plug
Old Jun 26, 2010 | 12:06 PM
subford's Avatar
subford
No it is over by the heater. If you short the plug on the clutch you will blow a fuse.
Old Jun 26, 2010 | 12:20 PM
kevinarnold021692
thanks for that i was about to look for one of those pics
but that low pressure switch arrow points to 3 plugs on that side
on that's plugged into the heater it looks like the other into the condenser and another that plugs into another plug
Old Jun 26, 2010 | 12:30 PM
subford's Avatar
subford
Here is the switch:
