Carb Spacer???????????
Old Jun 25, 2010 | 03:30 PM
460-67-FORD's Avatar
460-67-FORD
01 POWERSTROKE
I have a 460 .30 over aluminum performer rpm heads and intake msd ignition and a holly dominator do i need a carb spacer?????????? or how do you tell if you need a spacer???? THANKS
Old Jun 25, 2010 | 04:24 PM
704 dentside man's Avatar
704 dentside man
I don't think anyone actually needs a carb spacer unless there's a clearance issue. That being said, typically spacers are used to help 'performance'...I'm not so sure about it though. But, 4hole spacers are typically used to help in the low end and open spacers are used to help the top end. The height of the spacer is supposed to play a factor as well, the shorter it is, it's supposed to help the low end (I never got this, why not just eliminate the spacer and be as short as possible) and the taller the spacer is, the more it's supposed to help on the top end.
Old Jun 25, 2010 | 05:00 PM
Furyus1's Avatar
Furyus1
Spacers can also help prevent the carb from soaking up heat from the intake manifold and boiling the fuel out...
Old Jun 25, 2010 | 10:51 PM
79FordBlake's Avatar
79FordBlake
You might find out that you have to run a spacer. Sometimes the carb can get so hot after shut down the fuel boils out of carb, just like furyus1 said. Which will make it very embarassing trying to get it started again if you are in front of alot of people. Ive done been through all that, I greatly reduced the problem after pickin up a phelonic spacer from jegs. I went with the 1in, open spacer.
Old Jun 25, 2010 | 10:54 PM
79FordBlake
From my understanding for the most part a spacer is always a good thing. Keeps carb cooler, and lets the fuel/air mixture mix together better.
Old Jun 26, 2010 | 12:47 AM
460-67-FORD
01 POWERSTROKE
cool thanks for all the help everyone spacer it is
