Rear end conversion 1953 F-100
Old 07-18-2010, 07:40 PM
Classic Hauler's Avatar
Classic Hauler
Classic Hauler is offline
What would be the ideal later model rearend assembly to replace the original in my 1953 Ford F-100 and will fit within the perameters of the original rearend? I plan to use close to the original tire size.
Old 07-19-2010, 11:43 PM
fixnair's Avatar
fixnair
fixnair is offline
Welcome to FTE! You will find plenty of people willing to help. If you would move your request up a couple of boards to " 1948 to 60 F1 & F100" there has been a number of discussions on this very topic. And I'm sure you will get many answers.
Old 07-20-2010, 02:27 AM
55 f350's Avatar
55 f350
55 f350 is offline
67-72 ford 1/2 ton truck 9 inchers and some dana's in the mix too , are a direct bolt in , but if you intend to use original style shock mounts you'll have to find a set from a 53 - 55 f250 as the diffs in them have 3 inch axle tubes like the 9 inchers and newer danas . our oe dana 44 is what a 2 or 2.5 inch tube so the shock mounts wont fit the newer ones . also if you aren't afraid of a little work late explorer 8.8's fit too . as mentioned ya wander over to the 48-60 forum where most of us hide at you will find a wealth of info in the stickies up top , and in searching the past threads ........................
jlamb02910
03-25-2017 08:05 PM
jvmcc
08-08-2016 09:17 PM
Crazydan
03-29-2015 10:05 PM
RLanni
03-24-2011 10:47 AM
Crazydan
02-19-2006 11:16 PM
Quick Reply: Rear end conversion 1953 F-100
