:P well if nothing else u can always part it out lol
if u do get it id find some new heads and a 4bbl intake...
yea first thing thats going in is the heads. but quick question, when i replace heads is it a good idea to replace both sides at the same time? also, would it be better to replace the head with 2 broken plugs or drill them out and heli coil?
if u go back with stock heads u can do one but if its aftermarket performance heads do both...
i would try to remove the 2 broken plugs first...and heli coil them... then save up for some good heads
cool thanks. so ill do as you said, heli coil the 2 plugs. and save up. now is there like a complete kit i can buy to heli coil and how do i go about doing it exactly?
I paid 2k for my 85 f250 4x4. has its original 460 ci with original 94k plus miles with the 4 speed manual, have had no problems with it other than the original radiator cracking on the passenger take but replaced it for under $200.
Where have the plugs broken? Usually it would be just the porcelain insulators, so no helicoils or replacement heads would be needed.
Or has he shorn off the threaded sections? I haven't ever seen that happen.
not sure but as he said, he tried to Ez out and failed. when i get the truck ill take another look
