Flickering Check Engine Light, Loss of Power 1997 F150 5.4L
Old 08-22-2010, 04:18 PM
diver doug's Avatar
diver doug
diver doug is offline
Recently the Check Engine light would come on for a day or two and go out. Today it began flickering (later stayed on solid) and it had a loss of power and began running rough. The engine has 310,000 miles. What could this be.
Diver Doug
Old 08-22-2010, 07:11 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Diver Doug
At 310,000 miles it's probably telling you that it's tired and it's time for a rebuild. How is the oil pressure gage reading? Is it in the middle and steady or low and sometimes fluctuating rapidly? In the middle can still be low oil pressure as the gage will read "normal" at 7 psi and over.
Old 08-23-2010, 09:34 AM
diver doug's Avatar
diver doug
Thanks for the response. Oil pressure is good, always steady. The gauge reads a bit above the middle. When the milage was just about 200K I replaced the heads (pin hole leak had developed leaking out coolant). That was about 4 years ago. The truck has run great ever since then until now. Now I am thinking maybe the spark plugs. Does a check engine light occur when plugs start to mis fire? Or could this be a coil problem?
Old 08-23-2010, 10:12 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
[quote=diver doug;9249373]Thanks for the response. Oil pressure is good, always steady. The gauge reads a bit above the middle. When the milage was just about 200K I replaced the heads (pin hole leak had developed leaking out coolant). That was about 4 years ago. The truck has run great ever since then until now. Now I am thinking maybe the spark plugs. Does a check engine light occur when plugs start to mis fire? Or could this be a coil problem?[/quote]
It could be either and it will usually cause the CEL to come on and set a code.
Old 08-24-2010, 06:46 PM
iwmoose's Avatar
iwmoose
iwmoose is offline
I had the same thing happen to me and it was a spark plug problem.
Old 08-25-2010, 07:44 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
It is a misfire. Pull your fault codes so you know where to look. Most common failure is a COP.
Old 08-30-2010, 05:03 PM
diver doug's Avatar
diver doug
Thank you. I did realize the plugs had about 113K on them so I changed the plugs. For a few days the Check Engine light was off but the truck still had some hesitation and misfiring. After three days when passing on a hill the cutting out came back and the check engine light came backon, flashing. It flased for about 20 minutes and then stayed on continously. A few hours later the light is out. If this is a coil problem wouldn't I have continous sputuring and the light on?
Old 08-30-2010, 07:55 PM
projectSHO89
READ THE CODES! DO NOT GUESS.
Diver down
1997-2006 Expedition & Navigator
01-03-2016 02:13 PM
marine09
06-10-2015 01:24 PM
Steck804
1997 - 2003 F150
05-27-2014 10:07 AM
diver110
1999 to 2016 Super Duty
02-10-2011 08:19 PM
RichInTN
05-02-2008 04:47 PM
Quick Reply: Flickering Check Engine Light, Loss of Power 1997 F150 5.4L
