What kind of oil?
YOU HAVE TO PUT OIL IN THESE THINGS? OH CRAP!
What type of oil does your "Operators Manual" tell you to put in it?
1955 Ford truck owners manual items - Get great deals on Parts Accessories items on eBay Motors!
Your location makes a diff as well.
Ok I'll give in just this once and tell you what it says:
SAE 30 for temps above +32 degrees F;
SAE 20 or 20W for temps above +10 degrees F
SAE 10 for temps above -10 degrees F
SAE 5 for temps below -10 degrees F
If you have over 100K miles on it I might even go with SAE 40.
Since it is a flat tappet engine that needs ZDDP in the oil to keep from flattening the cam lobes, may I recommend Valvoline Racing Oil, which still has sufficient ZDDP in it. Other manufactures have radically dropped the percentage of ZDDP from their oils because isn't good for Cat Converters. B/B Ford turned me on to this stuff and it works great.
