Instrument Cluster Problem?
Old Jun 23, 2010 | 03:06 PM
JoeTaco1's Avatar
JoeTaco1
Thumbs down Instrument Cluster Problem?
I own a 1986 F150 and none of the instrument cluster works. Fuel gauge, oil pressure, everything isn't working. I've checked all the fuses.. any advice?
Old Jun 23, 2010 | 03:11 PM
smashclash's Avatar
smashclash
Did they all die out recently or did you just get the truck and you aren't aware the last time they worked? Do the gauge lights work when you turn on the headlights?
What about tach or speedo?
Old Jun 23, 2010 | 03:13 PM
JoeTaco1's Avatar
JoeTaco1
I bought it and they never have worked.. yes the gauge lights work, but barely.. the speedometer bounces back and forth, never detecting the right speed.
Old Jun 23, 2010 | 03:54 PM
smashclash's Avatar
smashclash
maybe a grounding issue somewhere.
Old Jun 23, 2010 | 04:15 PM
FordNFishinLover's Avatar
FordNFishinLover
Id first make sure the rear plugs are all the way in.
When removing mine and putting it back in for the first time i accidently hooked it in like 1/2 way and it didnt work.
Worth a try.
