Need some advice
Old Jun 22, 2010 | 11:42 PM
greg213187's Avatar
greg213187
Need some advice
I recently had the passenger side exhaust manifold replaced and the shop did a great job, however when I went to put the inner fender well back in I noticed a small black wire hanging near the manifold. I traced it to the firewall and would assume this is a ground wire I am just not sure where to attach the loose end.
Also the manifold that was replaced cracked on the portion closest to the front of the truck which water hitting it was suspected so I see the fender well has a raised area where it leaves the manifold more exposed in the front part, would it be ok to rivet a piece of rubber over that to keep water out of there better or is that a design for a purpose?
Old Jun 23, 2010 | 12:30 AM
southernpride01's Avatar
southernpride01
personaly i would cover the gap because i just cracked me 2nd manifold due to the same reason the manifold gets hot and expands the water cools it quickly causeing cracks and possibaly worping
Old Jun 25, 2010 | 06:19 PM
greg213187's Avatar
greg213187
I will try to get pictures up in the next day or two to see if that helps..
minnesotafisherman
41
Jun 10, 2021 04:33 PM
6978sghfbjklgdfsjhkl
23
Aug 23, 2012 05:23 PM
JD Powell
Large Truck
Apr 18, 2010 10:43 AM
doubleds truck
Escape & Escape Hybrid
Jun 14, 2007 03:11 PM
rc3
Oct 22, 2006 11:24 PM
