Sponsored by: Real Truck
EGR cooler issue?
Old Jun 22, 2010 | 10:11 PM
chevy_20's Avatar
chevy_20
EGR cooler issue?
Today I was towing my trailer back home and all of a sudden, what looked to be white smoke was pouring out the exhaust. It ended up being steam and from what I've read on here, it looks like my EGR cooler has bit the dust. I've got a '05 f350 w/ 6.0L, has 112,000 miles, and is completely stock. I haven't worked on a diesel before but worked on everything else I've got. I'm considering doing the egr cooler delete and was wondering what everybodies opinion is on that? How hard is it and how much time should it take? What else should I look at replacing while I have it apart? Is there any good instructions on the internet on how to do it? What are the best kits to work with? Thanks
Old Jun 23, 2010 | 02:34 AM
GregsSD's Avatar
GregsSD
It's pretty good that you made it to 112k mi. before having a problem with it, mine went at 35k mi.
you can do an egr delete or if you need to keep it smog legal you can get one of these egr coolers: BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0
You have to remove the turbo and the intake manifold to get to the egr cooler.
Old Jun 23, 2010 | 07:32 AM
hkaiser83's Avatar
hkaiser83
A lot of times the EGR cooler can fail because of a clogged Oil Cooler so get you a factory Ford Oil Cooler rebuild kit to do while you're down there. Oil Cooler is only accessible once the intake manifold is removed and you'll have it off anyways. Obviously get you the intake manifold gaskets. You'll want to check the EGR valve also to see if it's gummed up. I payed a ford certified master diesel tech to do mine for me (though I had him install a full egr system delete) and it took him approx 7 hours in my driveway.
You can definitely do it, but if you've never done it before I'd leave yourself a weekend or so to do it.
