Silly help on diff
Old Jun 22, 2010 | 04:50 PM
Ottneys250's Avatar
Ottneys250
Silly help on diff
Hey guys
I dont post to much but I read alot! I need a little help. I changed the diffrenial fliuid in my rear end of my 88 f250 5.0 non limited slip. I took the cover off and drained it out put the new gasket and cover on...but I cant find where the hole is to refill....I know this sounds silly but I have a nut at the top i broke loose and poored it in and it was pertty obious it wasent for the fluied...Any help before dark would be great lol
(oh I have 12 bolts on the diff cover if that helps anything )
Have a good one
Kyle
Old Jun 22, 2010 | 05:03 PM
zxwut?'s Avatar
zxwut?
Old Jun 22, 2010 | 05:04 PM
zxwut?'s Avatar
zxwut?
If you can't tell from the picture, it's not on the pan side. It's on the opposite side of the drain pan, on the driver's side.
Old Jun 22, 2010 | 05:09 PM
Ottneys250's Avatar
Ottneys250
OH Thanks
I looked where you said, and what I think it is it looks like a fill plug but to take it off its a squar...is that rite
Old Jun 22, 2010 | 05:10 PM
zxwut?'s Avatar
zxwut?
It's right.
Old Jun 22, 2010 | 05:12 PM
andym's Avatar
andym
Yeah you need a 3/8" ratchet end to take it out. If you need to use an extension use the shortest one you can find. Longer extensions make it harder to remove.
Old Jun 22, 2010 | 05:28 PM
Ottneys250's Avatar
Ottneys250
Thanks alot!
It came right out. One last thing I put a quart in there it took it all should I get another quart or is that about right...(My dad took my haynes)
Old Jun 22, 2010 | 05:42 PM
White 97 xlt's Avatar
White 97 xlt
Fill it until it just starts to run out of the hole!! I am assuming level ground here or close to it..
Old Jun 22, 2010 | 06:26 PM
zxwut?'s Avatar
zxwut?
Yep. Put it in until it starts coming back out.
Old Jun 22, 2010 | 06:35 PM
danr1's Avatar
danr1
F-250 and 12 bolts = Ford 10.25" shows it takes 7.5 US pints. (or 3.75 Quarts)
Old Jun 22, 2010 | 06:47 PM
Ottneys250's Avatar
Ottneys250
Yeh, When ever I put my truck in gear or in reverse it kicked really hard...I thought it was a tranny problem.
Diff prolly wasent serviced in a long time... It runs alot better and doesnt kick no more !
Anyways thanks for all the help runs alot better
Old Jun 22, 2010 | 06:49 PM
zxwut?'s Avatar
zxwut?
Check your u-joints also.
