1999 hub/clutch assembly install
Old Jun 22, 2010 | 12:45 PM
Shernius's Avatar
Shernius
I just picked up the hub/clutch assembly and it came with a pulley, hub, coil and a small bag of parts. In the bag is a bolt, C-clip and a bunch of washers.
What are the washers for and what is the torque for the bolt that holds it all together?
Do I just remove the bolt and a C-clip and it all just slides off?
1999 F150 5.4 engine.
Old Jun 22, 2010 | 06:43 PM
Shernius's Avatar
Shernius
Anybody know the gap for a 99 F150? I see .015-.030 is a general number.
Old Jun 22, 2010 | 07:28 PM
projectSHO89's Avatar
projectSHO89
That is the factory spec. Set it tight, it will last longer before it wears too loose.
Old Jun 23, 2010 | 12:10 PM
Shernius's Avatar
Shernius
Found that a 97 has an air gap of 0.018 - 0.033 inch. Since the shims that came with the assembly only allowed me 0.010, 0.025 or greater I went with the 0.025. Every thing worked fine this morning on the way into work and nothing flew off so I guess it's fixed.
Down the line if I need to I can remove one of the two (0.015 or 0.020) shims.
Jeremy Morgan
Offroad & 4x4
Jul 1, 2017 01:38 PM
DoeyDooper
1983 - 2012 Ranger & B-Series
Feb 14, 2017 10:30 PM
Mikeno11
Offroad & 4x4
Oct 18, 2016 03:40 PM
olderf150
Feb 26, 2016 10:04 AM
Rocky Mountain F150
Sep 11, 2012 07:55 PM
