Another problem
Old Jun 22, 2010 | 10:57 AM
mh5500's Avatar
mh5500
Another problem
I flushed my cooling system last week with VC-9 and distilled water and filled it back up with Ford Gold Antifreeze. Since then, the fan wants to run pretty much all the time. I'm pulling a trailer. The truck is a 2003 all stock - never been chipped. I never noticed it running like this before I flushed it. The fan keeps cycling on and off.
Old Jun 22, 2010 | 07:11 PM
cheezit's Avatar
cheezit
you need to check ect/eot and see what they are doing. the upside hear is the fan seems to be working.
Old Jun 22, 2010 | 07:16 PM
steelhead2's Avatar
steelhead2
could it have an air pocket somewhere?.if it just stated after flushing your coolant i'd try getting the air out of it.
Old Jun 23, 2010 | 07:15 AM
mh5500's Avatar
mh5500
How do you get the air out?
Old Jun 23, 2010 | 11:45 AM
KRDiesel's Avatar
KRDiesel
Take off the cap on the degass bottle, make sure it is full and let it idle for 20 minutes. refill bottle, and then run the **** out of it for awhile, it will purge on it's own. Also run the heat on high to purge that system.
