intake question
Old Jun 22, 2010 | 10:16 AM
petey shoes's Avatar
petey shoes
intake question
can you folks tell me whether a 8rt intake manifold will fit an 8ba? is heat riser plenum the same? anyone block off the heat riser and have decent results? keep in mind i'm in ny. if i block off riser, would it make sense to drill small ports in order to get some heat in cold weather?
Old Jun 22, 2010 | 11:06 AM
52 F3's Avatar
52 F3
8rt-8ba Same block. Should be a direct swap.
