Sponsored by: Auxito
grinding from starter?
Old Sep 1, 2013 | 04:20 PM
harrisonpromo39's Avatar
harrisonpromo39
I also have a 2000 F150 and It's only once in a while but it does the same as you are speaking of. I am gonna inspect the Flywheel myself wandering if it is a glitch in their starters? since it's happening to many others.
Old Sep 6, 2013 | 10:00 AM
Rman1159's Avatar
Rman1159
I have had the same problem with my 2000 F150 5.4l I replaced the flywheel and starter and cables and battery last year. It worked ok for a few months and now it's back. I am going to put it up on a lift and remove the inspection plate and see if it engages all the way. Also this is the third starter in 10 yrs. Does anyone have the right fix.
Old Sep 11, 2013 | 01:51 AM
98_F250's Avatar
98_F250
I also have this problem once or twice a month on my 98 f250 LD. Currently I just release the key and it always fully engages on the 2nd try. Before I go through and needlessly start replacing everything, I am hoping someone out there knows what is the MOST prevalent cause(s) based on their fix/experience.
I only have 36,000 mile on it, and plan on keeping my truck for 10 more years. I prefer to fix it now, rather than in the grocery store parking lot with ice cream melting or at lowes with 40 sheets of drywall loaded, and a crew waiting.
Thanks in advance for your help!
nothercrash
16
Jul 1, 2015 10:45 PM
Aviator2011
Bronco II
May 30, 2012 11:34 PM
rmckenna
Sep 14, 2006 04:30 PM
sadbroncowner
Bronco II
Dec 20, 2005 10:50 AM
88f150*300
1997 - 2003 F150
Mar 21, 2004 03:06 PM
