dip stick ?
Old Jun 21, 2010 | 02:52 PM
drunkenrich's Avatar
drunkenrich
dip stick ?
hey guys
I recently did a rebuild and had to get a new dip stick cause other one was rotted. My question is: does the dip stick have a gasket or o ring that goes on it where it goes into the block? Seems like a loose fit and oil is leaking from that area, it is either that or the new oil pan gasket. thanks
Old Jun 21, 2010 | 03:34 PM
ac700wildcat's Avatar
ac700wildcat
I'm doing an engine swap right now and neither motor has a o-ring that I can tell. I'm going to clean mine up really well and put some silicon on it and let it dry really well before I run it.
Old Jun 21, 2010 | 03:36 PM
Old93junk's Avatar
Old93junk
No O rings on dipstick tube.......press fit.
Just use some permatex to seal it if leaking.
