Tire Question
Old Jun 20, 2010 | 03:31 PM
basspro620's Avatar
basspro620
Tire Question
What's the maximum size tire i can put on my truck? It's a 2wd, stock height, and no suspension work. I'm planning on running 17 inch wheels when i go to purchase wheels and tires
Old Jun 20, 2010 | 05:31 PM
Rockstone's Avatar
Rockstone
Probably something around a 235/65x17 depending on offset.
Old Jun 20, 2010 | 08:11 PM
basspro620's Avatar
basspro620
Right now i'm runnin 255/70R15's which is 29.1 inches tall. I'm plannin on runnin 265/70R17's. would i have any clearance issues with the 265's?
Old Jun 20, 2010 | 08:21 PM
Rockstone's Avatar
Rockstone
A 265/70r17 is going to be 31.6" tall. Your 255/70r15's are 29.05". Do you have that much more clearance? The 235/65r17's will be 29.02".
Old Jun 20, 2010 | 08:54 PM
basspro620's Avatar
basspro620
I've got plenty of clearance top to bottom, it's just rubbing the frame im worried about
Old Jun 20, 2010 | 09:00 PM
Rockstone's Avatar
Rockstone
You wheel offset is going to come into play there. Maybe somebody else who has run that combination will chime in. Good luck.
Old Jun 21, 2010 | 07:58 AM
Grubbworm's Avatar
Grubbworm
I'm running 31x10.50x15's on my truck, 2wd, no suspension mods. I have 8.50 aluminum wheels (no idea what the back spacing is). The front tires rub slightly when going over severe bumps or dips (I think on top of the tire, as there are no obvious marks).
Old Jun 21, 2010 | 05:13 PM
basspro620's Avatar
basspro620
The wheels i'm getting are 17X9's. maybe I can't make up my mind, HAH! but i'm not going any bigger than 17's unless i can find a good deal on a set of 18's. As for tires i'm really liking the new Goodyear Duratrac's.
Old Jun 21, 2010 | 05:23 PM
Redneck1465's Avatar
Redneck1465
Refer to this thread for what to do.
https://www.ford-trucks.com/forums/8...-question.html
Put those in your front springs and you will be fine.
Old Jun 23, 2010 | 05:10 PM
basspro620's Avatar
basspro620
My truck sits level already so i don't need any more lift in the front.
Old Jun 23, 2010 | 07:53 PM
smashclash's Avatar
smashclash
sorry to hijack but anyone confirm if this will work for me.... my spare tire was shot so i got the spare off a 94 bronco. it's got a goodyear wrangler on it 265/75/R15. I currently have 31's on the truck right now. no height clearance issue but there are rub marks on the radius arms but i'm not worried about that. i'll admit the 265 looks awfully wide....
Old Jun 24, 2010 | 08:49 AM
Grubbworm's Avatar
Grubbworm
If you are going to keep the odd tire out on your vehicle for any length of time, I would put it on the rear. If you put it on the front for any extended period of time, you run the risk of throwing out your alignment. That being said, you will also affect your rear end (bearings, seals, etc.) if left on for an extended period. I have 31x10.50x15's on my truck, but my spare is a 255/70/15. I have never had to use it as a spare, but it is a left over from the second set that I ever put on the truck.
Rudiak
Dec 9, 2017 08:52 AM
craigwieck
Ford Truck Parts for Sale
Jun 25, 2013 06:16 PM
99hosss
Aug 1, 2012 07:32 AM
mainevent223
Apr 29, 2008 08:08 PM
WILLIAM HORNSEY
2004 - 2008 F150
Mar 6, 2006 05:55 AM
