Radiator in the bed
Old Jun 20, 2010 | 02:13 AM
FatBoyzCustomz's Avatar
FatBoyzCustomz
Radiator in the bed
Ok so i decided to put my radiator in the bed of my truck. Ive got a lightbar to put back there and was gonna put the radiator at an angle between the legs of the lightbar. Ive got a 16" electric fan to go with it. What im wondering is how well will this work? i figure with no radiator in the way of the grille more air will get the engine compartment plus i will still have a very cool radiatior in the bed. What im hoping for is the air that comes over the cap will come down and cool the radiator. What are the positives and negatives of this approach?
Btw its a 77 f250 Highboy with a 460.
Old Jun 20, 2010 | 03:04 AM
bobwires's Avatar
bobwires
It's going to work, but it's not worth it unless you have a reason to relocate. Sounds like a hassle, for minimal gain to me.
Sand racers put radiators up top or in the rear to keep them clean, and rear/ mid engine cars have lots of setups, but usually run the pipes all the way to a radiator in the front.
If you need to keep the engine bay cooler for some reason look into hoodliners, header wraps, etc.
Old Jun 20, 2010 | 03:23 AM
Hickfied's Avatar
Hickfied
I've only seen rear mounted rads used for two reasons.
One, racing offroad, to keep debris out of it.
Two, When going with large twin turbos, and even then, some people opt to just put the turbos out back.
Old Jun 20, 2010 | 03:34 AM
FatBoyzCustomz
this trucks going to be offroad a good bit but the more i look into it this setup seems to overheat at highway speeds
Old Jun 20, 2010 | 07:17 AM
Joseph69's Avatar
Joseph69
You will need a high volume water pump to pump the water all the way to the back and then to the front. Not good for street use. Should not overheat because the metal piping running to the back will dissipate heat also.
Old Jun 20, 2010 | 08:26 AM
Diesel_Brad's Avatar
Diesel_Brad
It also adds a couple of gallons to the capacity too, so that helps cool things. I would use bigger than a 16" fan though, or 2 of them
