STUMPED Perfomax question
Old Jun 19, 2010 | 04:54 PM
Sheryle's Avatar
Sheryle
I'm using the wire installation tool. Does it matter which wire goes into which slot? Thanks I can't go any farther until I know.
Old Jun 19, 2010 | 06:51 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Performax gauges? Not quite sure what you asking. Details help.
Old Jun 19, 2010 | 07:14 PM
Maxium4x4's Avatar
Maxium4x4
Here is a write up on installation from 4 Wheeler magazine. It leaves me confused....
Old Jun 19, 2010 | 08:00 PM
1957F100's Avatar
1957F100
Are you talking about on the orange plug that plugs into the back of the gauge?
If so the orange connector is numbered. The orange wire goes in number 1, white goes in 2 and black goes in 3. Number 4 is left empty.
If that doesnt answer your question let me know. Also when I installed the gauges I used that stupid little platic tool they send you and at first 2 of my gauges werent working. The tool didnt push them in far enough into the connector to pierce the insulation on the wire. I ended up taking a flat head screwdriver and really pushing the wires in there.
Also where did you decide to mount the ESP module?
Old Jun 19, 2010 | 09:21 PM
Sheryle's Avatar
Sheryle
Thanks fellows.
Lubbockguy1979 I was talking abour IssPro gauges that use a "junction block" called an ESP. Once it is installed they say you can daisy chain up to 16 gauges without running any more wire in the cab.
Maximum4x4 I agree that article is about as clear as the directions from IssPro. You would think that buying "top of the line" gauges would get you a little more detailed instructions, heck maybe even a few color photos.
1957F100 That is the information I needed. After you gave me the answer I see the reference in the ESP installation sheet. I can't believe I missed it. haha. quote THE ORANGE, WHITE AND BLACK WIRES ARE THE +7V........blah, blah, ......CONNECT TO THE CAVITIES1,2,AND 3OF THE ORANGE CONNECTOR RESPECTIVELY. unquote
The way I read it the first time I thought the black tool instructions. I thought it was part of the assembly. I got 4 with 3 gauges.
Well it is all installed, well one gauge is installed and does not work. Got fire, got ground so it must be somewhere else.
Tomorrow..
Thanks again!! Maybe Michael with IssPro will read this.
Old Jun 19, 2010 | 10:16 PM
1957F100's Avatar
1957F100
Glad you got it figured out. Which gauges did you get?
Also I am not sure if michael from Isspro is on the site. I know he is powerstroke.org and I have dealt with on there before. You can also email him. I have had some problems with my performax gauges and I dealt with him through email and he was very helpful.
Old Jun 19, 2010 | 10:20 PM
texans's Avatar
texans
Sheryle. Did you get those injectors installed yet. Just wondering how everything is going for you.
Old Jun 19, 2010 | 10:51 PM
Sheryle's Avatar
Sheryle
I bought the Performax Black w/red pointer. For now I have the Fuel Pressure, Boost, and EGT. Was using an old model Edge to monitor Boost and EGT. Never really trusted it and it would get squirrely at times. Just did not realize the time and effort involved .
Cover the basics and then injector install. The current stock injectors are on their last leg. No magic potion this time. This set has about 115k miles on them.
Old Jun 21, 2010 | 02:59 PM
Sheryle's Avatar
Sheryle
Performax ESP location
1957F100, I was re-reading the post and saw I did not answer your question about the ESP location. I attached it to the driver side inner fender on the cabin side of the power steering reservoir. Seems to have plenty of room.
Another complaint while I am at it. Why not have mounting holes in all 4 corners of the ESP rather than just 2?
Old Jun 21, 2010 | 03:23 PM
Lubbockguy1979
I have the ev series. The instructions were crap on those as well. Took me some trial and error. When I reinstall them on my new truck I will do it 100% faster and different. Funny once you do it once it makes it a lot easier.
Old Jun 23, 2010 | 08:15 PM
Sheryle's Avatar
Sheryle
It' me again
Found a little time to work on the gauges. I finally found the numbers on the orange plug and by dumb luck I had them installed correctly. Fuel pressure gauge still does not work. Got full time power, got switchable(new word?) power, good ground and dimmer wire hooked up. I checked the voltage where the orange wire connects to the orange plug and had 0V switched off and 7V switched on. Gauge pointer does not budge. Any words of wisdom, suggestions or ideas of what I can test now. I have a brand new $60 multimeter that tells me the same thing the 15 year old one tells me. Thanks
Old Jun 23, 2010 | 08:54 PM
1957F100's Avatar
1957F100
Does the gauge pointer move at all when you turn the key on or start the truck? You said it doesnt budge but the pointer should move up a hair off of its seat.
If the gauge isnt moving at all I would say it would either be a connection at the back of the gauge or maybe the gauge itself is messed.
Like I said before when I first installed my gauges two of them wouldnt work. Turns out the wires werent pushed into the orange connectors enough to pierce the insulation of the wire. A good way you can check the wiring for that gauge would be to take one of the gauges that is working and plug it into the spot of the one that isnt working. If that gauge doesnt work then the problem is with the wiring. If it does work than something might be wrong with your fuel pressure gauge.
Edit-I just reread your post and saw where you said you already measured 7V at the orange wire. Are you checking the voltage on the back of the connector. or actually unplugging it from the gauge and checking it from the front where it connects to the gauge?
Old Jun 24, 2010 | 04:55 AM
Sheryle's Avatar
Sheryle
I checked it from the back with it plugged in.
I thought about trying another gauge inthe slot, but did not try it because the other gauges I have are boost and EGT. Of course I could hook up the engine side one of those to check. At least eliminate one possible cause at a time. I will try to get time to do another today.
tdpower
Sep 11, 2011 09:07 PM
cpetersen
Jan 13, 2011 06:55 PM
kirkharrod
Sep 21, 2009 09:30 AM
BOOTROS
Electrical Systems/Wiring
Jul 1, 2005 02:40 AM
jhobbs26
Oct 15, 2004 04:19 PM
