rough idle at start
Old Jun 19, 2010 | 12:53 PM
BLK 96's Avatar
BLK 96
rough idle at start
My truck just started having a extremely rough idle when i start it in the stock position on the chip, when i switch the chip on it starts ok. When it idles rough in stock the OD light on shifter was flashing Hope someone can help.
Old Jun 19, 2010 | 01:02 PM
DRRXR's Avatar
DRRXR
Need to get the codes pulled on it and post back
Old Jun 19, 2010 | 01:22 PM
BLK 96's Avatar
BLK 96
how and where do I get the codes pulled?
Old Jun 19, 2010 | 01:29 PM
DRRXR's Avatar
DRRXR
If your truck is obdII then there is a connector near the glove box but under it. If your Turck is OBD 1 its either to the left of your knee when driving or under hood.
What year is it?
You may be able to get a parts store to scan it, however some scanners dont work on our trucks.
Old Jun 19, 2010 | 01:33 PM
BLK 96's Avatar
BLK 96
It is a 96 F 250.
Old Jun 19, 2010 | 01:56 PM
DRRXR's Avatar
DRRXR
You should be OBDII check to the left of the glove box.
Here is some more info
http://www.fmsgps.com/frontend/PDFs/...aper_OBDII.pdf
Old Jun 20, 2010 | 10:09 PM
BLK 96's Avatar
BLK 96
I went and had the codes pulled but there wasn't any codes , the check engine light is not on. It idles rough in the stock position and does not do it when the chip is on. Any suggestions on what it might be will be helpful thanks.
Old Jun 21, 2010 | 04:25 AM
DRRXR's Avatar
DRRXR
Do you have a idm mod? I would contact the manufacturer of the chip about this issue.
Other info but I dont think its your problem.
03-21-37***ROUGH IDLE - NEW TOOL FOR TESTING ROUGH IDLE - INJECTOR PERFORMANCE ANALYZER - SERVICE TIP
