4 barrel holly will fit but 4 barrel edelbrock wont.
Old 06-17-2010, 07:43 PM
'83f3fiddy's Avatar
'83f3fiddy
'83f3fiddy is offline
so my friend gave me a working edelbrock carb. its a 1405. the throttle cable wont fit to the carb..tho on my holly it was too long..is there an adapter i can get somewhere (cant find anything on edelbrock.com) to make it work?? i would use my holly but 1 of the main jets (thats IN the barrel) is destroyed...
Old 06-18-2010, 08:25 PM
84_F150's Avatar
84_F150
84_F150 is offline
i never had a problem with my edelbrocks.. post a picture of your carb linkage.. i may be able to help
Old 06-18-2010, 09:04 PM
'83f3fiddy's Avatar
'83f3fiddy
ok ill do that tomorrow
Old 06-18-2010, 09:15 PM
'83f3fiddy's Avatar
'83f3fiddy
but form what i can see the edelbrock is wider, and the "go fast" lever is quite a bit farther forward..oh and i have a 351W with an edelbrock intake if that means anything...and the throttle cable is like 1-2" behind where it would connect to the carb..but yet the holly fits with no issues..
Old 06-18-2010, 09:17 PM
84_F150's Avatar
84_F150
84_F150 is offline
are you running a kick down cable? and what type of throttle cable bracket are you running?
Old 06-18-2010, 10:22 PM
'83f3fiddy's Avatar
'83f3fiddy
i dont use the kick down..and im using the stock throttle cable
Old 06-18-2010, 10:25 PM
84_F150's Avatar
84_F150
84_F150 is offline
are you using the stock cable bracket?
Old 06-18-2010, 11:27 PM
'83f3fiddy's Avatar
'83f3fiddy
yeah, is that the issue?
Old 06-19-2010, 01:31 AM
84_F150's Avatar
84_F150
84_F150 is offline
no.. i ran my stock 1 too.. but i believe it flipped it around the other way
Old 06-19-2010, 02:42 AM
'83f3fiddy's Avatar
'83f3fiddy
well it seems as if the cable itself is too short..where it connects to the carb the carb would have to be back a lil ways..
Old 06-19-2010, 07:22 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
I too have not had a problem.
Old 06-19-2010, 09:36 AM
84_F150's Avatar
84_F150
84_F150 is offline
oh, ok.. so you already have it bolted on to where the cable sits further forward?
someone please correct me if i'm wrong.. but isn't the I6 cable longer from the bracket tab to the end? mine may have had a I6 cable because it was originally an I6 truck
Old 06-19-2010, 02:13 PM
'83f3fiddy's Avatar
'83f3fiddy
im lost in that ^^^^
but the cable sits farther behind the carb now..
Old 06-19-2010, 02:23 PM
'83f3fiddy's Avatar
'83f3fiddy
here is what it looks like..but when i connect the cable the carb opens up about 1/4 way is there a way to remove the choke? cause it looks like i could run it on the inside of the bracket and it would work.. but the choke is in the way..
and YES thats zip ties holding the cable into the bracket..
i dunno if this would help or but but here ya go
Old 06-19-2010, 04:06 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Could very well be the way I'm looking at it, but can't you just move the bracket to the bolt in the intake?
Quick Reply: 4 barrel holly will fit but 4 barrel edelbrock wont.
