HPOP Question
Old Jun 17, 2010 | 12:43 PM
jbounds's Avatar
jbounds
HPOP Question
If im not mistaken I remember seeing a thread about the Late 99 - 03 7.3's having a bigger degree or what not on the HPOP i think it was 17* where as my E99 has 14*?? Which i believe it would be better to have the bigger one correct? Now if so what does it affect...do i get better performance....fuel mileage? And also how hard is it to swap out the HPOP's? is it a day job or a couple hours? Sorry for all the questions just couldnt find a thread to answer them.
-Justin-
Old Jun 17, 2010 | 12:50 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Justin, your Early 99 has the 15* HPOP and the late have a 17*. Your best bet is to give Bob a call and he can line you out on what you will need to swap. It will give you a little better SOTP performance and possibly some mileage but I wouldn't count on that part. If you can find a clean 17* in a junk yard I would send it to Joey @ Terminator, have it modded and run it.
Replacement O-rings for Ford Diesel Engines
Old Jun 17, 2010 | 01:25 PM
rat49f6's Avatar
rat49f6
Id be more than happy to help u install ur hpop it only takes me 2hrs start to finish now. I highly reccomend a sending your pump to Joey, once you find a 17* pump that is.
