question on brakes
Old Jun 16, 2010 | 08:16 PM
$100special's Avatar
$100special
question on brakes
Just wanted to get some expert opinions. My brake pedal is not returning back up and seems a bit mushy. Replaced calipers and bled the brakes but didn't really help. Brake booster bad? Not much left.
Old Jun 16, 2010 | 08:44 PM
Franklin2's Avatar
Franklin2
Did you bleed the rear brakes also? Have you adjusted the rear brakes? Push the e-brake on and see if the pedal height improves.
Old Jun 17, 2010 | 12:22 AM
Opossum's Avatar
Opossum
You most likely need a master cylinder, it has a return spring that should push your pedal back up no matter what is going on with the rest of the brakes. So most likely it is either gummed up or that spring broke.
Old Jun 19, 2010 | 02:16 PM
$100special
thanks, replaced the master cylinder and all is good. TOok it for its first time on the road in 2 years and it made it to the local gas station and back lol
