Up Pipe Removal?
Old Jun 16, 2010 | 04:15 PM
04scurs's Avatar
04scurs
Question Up Pipe Removal?
Is there any special(secret) way to get to the up pipe bolts and nuts to take them off while the motor is still in the truck? Also I don't have a hoist so it is either laying on the shop floor or going in from the top.
I am in the middle of an EGR delete and this step seems to be the most difficult.
Thanks for any help here.
'04' Ex w '03' motor and 4'' Banks exh.
Old Jun 16, 2010 | 04:19 PM
ADAMZ's Avatar
ADAMZ
Take the passanger side inner fender well out and you then can get to all the lower bolts with no problem. Just did this to my truck with no problems. You will have to take the passanger side front wheel off to get the fender well out.
Old Jun 16, 2010 | 04:21 PM
Hank85713's Avatar
Hank85713
if you are talking of the turbo down pipe it is a pia but can be done. Ya gotta pretty much lay over the engine and use a 7/16 wrench I think it is to loosen/tighten. It is a V clamp so has to be almost totally apart to remove. I had mine on a hoist and was a YO YO up and down but I finally got it figured out.
Old Jun 16, 2010 | 04:51 PM
SHAWN056.0's Avatar
SHAWN056.0
Soak em down with some pb blast or wd40. I used a few extensions to get up to em. Might be easier if u have the turbo out of the way but it's still a pia.
Old Jun 16, 2010 | 05:05 PM
tex25025's Avatar
tex25025
It's a little easier with the turbo out of the way, but getting the turbo out of the way is a chore in of itself.
Old Jun 16, 2010 | 05:26 PM
npccpartsman's Avatar
npccpartsman
IIRC you have to take the turbo out. It's much easier and faster than trying to fight to get to the bolts and it will give you an opportunity to clean the turbo if it needs it.
Old Jun 16, 2010 | 07:36 PM
cheezit's Avatar
cheezit
lamo man some people like to work hard.
remove turbo. pull pipe up from the top
to remove the pipe to maifold bolts use a stuby wrench and 16-18" long extension. go between the frame rail and the fender liner to access.
Old Jun 17, 2010 | 09:43 PM
Benchwrench's Avatar
Benchwrench
If it helps, check out this thread https://www.ford-trucks.com/forums/7...tructions.html
Old Jun 18, 2010 | 10:00 PM
04scurs's Avatar
04scurs
Thanks for all of the input. It helped alot.
FuzzFace2
25
Nov 17, 2020 04:31 AM
Deanp88
6.4L Power Stroke Diesel
Feb 8, 2017 10:13 PM
PinkyRingz
Oct 20, 2016 10:16 AM
jk349
Aug 20, 2016 06:17 PM
helifixer
Jul 10, 2016 01:12 PM
