EPOXY PRIMERS
Question 2. If there is such an animal what is the best brand to use for a primer base that will be on it for at least 12 months?
The truck was from Nevada. It has virtually no rust except some surface stuff in the usual places: bed, impact areas, floor.
I plan on using POR 15 prior on those areas ( mainly because there is a distributor local who should be able to help me application-wise ).
My plan is to drive the truck this summer into fall and then garage it, pull apart the front clip, bed and start my POR 15 ( Extensive application ), clean up the engine compartment, body work, and paint prep and then have it shot next spring.
Questions 3. Should I do the POR 15 now ( warm weather ) where I can easily access? Areas like the floor, rockers, underside of cab ( again areas of easy access ) and fender wells?
I'm not going to pull the cab. I really don't have the ability and, it and the frame look awesome. I just want to protect it as much as possible short of a frame off project.
